Several Reasons Why the Fixed Jaw Crusher Has Low Yield
  • Several Reasons Why the Fixed Jaw Crusher Has Low Yield
    1. Material hardness is unqualified
    The hardness or toughness of the material to be crushed exceeds the range specified in the instruction manual. When it does not reach the range specified in the instruction manual, the fixed jaw crusher machine should be replaced or added.
    2. Motor connection position is reversed
    The connection position of the motor of fixed jaw crusher machine in China Hongxing is reversed, the host drives the car in reverse (the jaw rotates clockwise), or the triangle connection of the motor is connected to the star connection. If the motor position is found to be reversed, the motor connection can be changed.
    3. The discharge opening is less than the requirement
    The output of the fixed jaw crusher machine does not reach the factory standard, it may be because the discharge port is smaller than the specified limit. In this case, the discharge port must be adjusted to the nominal discharge port specified in the manual and a crusher for fine crushing must be added.
