Hydraulics issue with Landini 10000
  • Selmir Bosnia
    • 22/11/2024
    Hi all! I am new member, come from country Bosnia (your neighbour over the Adriatic sea, next to Croatia). I am mechanical engineer but I also do agriculture and produce wheat and corn on 10 hectares.
    After I introduce myself, I need to ask for some help. I have Landini 10000 built in 1984. Engine is Perkins 6.354, works like a charm, smokes a bit but it is OK.
    I have a very strange issue with my lift hydraulics since spring. On the right side I have a two levers, the outer one is for draft/position/mixes control. The inner one, closest to the seat, lifts and lowers the lift arms.
    If I set the control lever to draft, my lift control lever has no function and lift arms will not go down. If i set it into mixed, they get lower a bit. IfI set it to positon,I canot push the lift control lever to the lowest position and lift arms will not go down. If I have something heavy (like 100kg) the will go down but I have to hold the lift control lever by force - if I release it, lift arms go up a bit on their own.
    It is very hard to use tractor like this, If i am doing some plowing or tilage I have to gently hold the lift control lever all the time in the lowes positon otherwise the plow or other implement will get lifted out of the ground.
    I also have two more externa hydraulic valves for external cylinders and front hydraulics and they work normaly. I checked the oil level, filters, everything is normal and clean.
    Anyone has any idea what to do?​
