Montaggio di gru a torre in "luoghi difficili"
  • Montaggio di gru a torre in "luoghi difficili"
    Ciao a tutti.
    Apro questo argomento per farvi vedere due "resoconti di montaggio" di due gru a torre (una Potain e una Liebherr) in quota.
    Vorrei chiedere se qualcuno di voi ha avuto occasione di vedere cantieri del genere oppure di lavorarci
    Originalmente inviato da KHL Group
    High steaks
    The task of transporting a tower crane to the site of a restaurant development more than 2.5 km up a Swiss mountain went to the lifting power of the country’s largest helicopter.
    Placing the eight-tonne capacity flat top Potain MDT 132 tower crane into position on the Arosa Weisshorn, at an altitude of 2,653 m, took careful planning. Potain dealer Stirnimann supplied the crane to sub-contractor Andrea Pitsch for the restaurant build which includes staff accommodation, a ski room, cold storage and kitchen, along with an upper floor dining area for 182 people.
    Lorenzo Cassani, Stirnimann president and general manager, said that although difficult, the assembly project was not unusual. “We have our own team of Manitowoc Crane Care technicians on hand who know the region, the environment and the equipment,” Cassani explained.
    Stage one saw the transportation of the crane’s components to the Midway Station, using the mountain’s cable car. They were then taken the final 650 m by the Kamov heavy-lift helicopter operated by local company Helog-Heliswiss. The helicopter has 15.8 m co-axial rotors and is powered by two 1,660 kW turboshaft (gas turbine driving a shaft instead of jet thrust) engines.
    “The total weight of the crane is 30 tonnes and it is larger than many cranes that would be selected for a project such as this. But the nature of the construction required the lifting ability of the Potain. We fitted a 50 m jib and erected the crane to 22 m height under hook, but we managed all this in only 17 trips with the helicopter,” explained Cassani.
    The assembly process was completed in a day but, Cassani explained, that there was still a lot of work to be done once the crane was on site. “For example, to bolt the slew ring to the structure our technicians used their torque wrenches to install 116 bolts. A very difficult task in such an exposed location,” he added.
    Originalmente inviato da Liebherr.com
    Un elicottero installa una gru a torre in Svizzera
    Un elicottero ha installato recentemente una gru girevole a torre Liebherr modello 30 LC a oltre 3.300 m di altezza sul Corviglia Piz (Svizzera). La gru sarà impiegata per interventi di ristrutturazione e modifica della stazione a monte della cabinovia Corviglia, in esercizio da 44 anni.
    Per poter effettuare l'intervento, la 30 LC è stata montata su un carro mobile con 3 m di carreggiata scorrevole su rotaie e su una struttura di basamento a torre di 12 m di altezza. La gru raggiunge in questo cantiere un'altezza di gancio di 11,20 m ed uno sbraccio di 24,70 m. Per garantire la stabilità anche quando la torre non è in esercizio, la 30 LC è stata ancorata con cavi per resistere a venti fino a 200 km/h.
    Per l'installazione è stato impiegato un elicottero da trasporto pesante modello K-Max, in grado di sollevare tranquillamente ed in piena sicurezza fino alla destinazione prevista pesi fino a 2.700 kg. Poiché i singoli componenti costruttivi della 30 LC pesano max. 1.700 kg, la gru risulta particolarmente adatta per installazioni speciali di questo tipo.
    Grazie alla precisa pianificazione logistica del team di montaggio ed alle eccellenti prestazioni di volo del pilota, è stato possible completare l'installazione della gru a torre Liebherr in sole 4 ore. Per il trasporto di tutti gli elementi, inclusa zavorra e contrappesi, sono stati necessari complessivamente 28 voli. Cinque voli con l'elicottero hanno dovuto essere eseguiti dalla stazione a valle, poiché gli elementi non potevano essere trasportati con la funivia fino alla stazione intermedia.
    ciao kxmet ma in quanti montatori erano per montare la 30lc? ultimamente ho avuto occasione di montare e smontare una gru auto montante a funi e ho visto che non è proprio cosi semplice
      ciao kxmet
      potresti mettere i link delle foto in modo da poterle vedere ingrandite?
        Originalmente inviato da gianni75 Visualizza messaggio
        Purtroppo non ho altri dati oltre a quanto scritto negli articoli.
        Originalmente inviato da angelo90 Visualizza messaggio
        ciao kxmet
        Le foto sono nelle dimensioni originali in cui le ho trovate sui siti, non c'era la possibilità di ingrandirle.
          alcuni video del montaggio con elicottero di una delle due gru sul Castello di Calatabiano in provincia di Catania
            a vedere i colori la gru sembra una raimondi...giusto?
              esatto.... sono due raimondi MRT
                Spettacolare!
                Chissà com'è difficile fare un lavoro del genere, sia per il pilota che per i montatori...
                  ecco un altro bel montaggio in quota.
                    anche questo deve essere stato un bel montaggio:https://www.simegroup.it/cgi-sime/es...20717261314697
                      Buonasera a tutti,al seguente link trovate alcune foto del montaggio di una Comedil che ho fatto alla Stazione Banc della Marmolada.
                        Ciao a tutti presto inserirò delle foto di un montaggio di una terri tsx 40 alta 42 a Taormina sul Corso e di una altra terri tsx 40 alta 45 sempre a Taormina...
                          Ma che marca è la Terri ... ??? ... Semmai una Tabaresh o Soima o Comansa oppure una TGM ...
                            Originalmente inviato da SaBlu Visualizza messaggio
                            A dire la verita' ne ho viste diverse anch'io, magari sara' il marchio del distributore o noleggiatore, rimane il fatto che e' l'unico marchio visibile su dette gru, e anche bello grande!
                              date un occhiata quà
                              è proprio la marca delle gru,e fanno anche belle macchine di una certa grandezza,l'ammiraglia è una 80 mt di braccio con 7 ton in punta e 24 di massima.
                                Teo le Gru Terri non esistono nel senso di azienda di quel nome che le produce ... Fidati ... La società che distribuisce le gru per differenziarsi i settori ha preferito chiamaris Terri per le Gru , così come ha altri settori come movimento terra e altro che li definisce con altri nomei come Karni e Unicorno ... Le gru sono Comansa o Tabares ... Garantito al limone ....
                                  la terri è la divisione gru della mevi ed una società distributrice che si fa produrre le gru dalla soima e dalla comansa in passato dalla comedil e tgm
                                    Originalmente inviato da scarpigru Visualizza messaggio
                                    Mi mancava la Soima , buono a sapersi , in ogni caso giusto per la precisazione non è che la Soima o la Comansa le produce apposta , ma in realtà sono gru che seguono la produzione normale a cui la qualcuno mette la targa Terri .
                                      ma presto caro saBlu ci saranno delle novità che se vorrai ti farò sapere..e comunque le soima montano motori leroy somer propio come le potain..
                                        Caro Scarpi non so tu quale novità stai parlado , ma sarò sicuramente lieto di leggerle. Riguardo ai motori Leroy , è vero che Soima monta tali motori , ma devi anche sapere che tale azienda ne produce tanti ma quelli che usa per Potain non li trovi di certo montati su le altre marche e comunque Potain al momento non usa solo motoriLeroy.
                                        Tanto per farti un esempio , la Toro Rosso monta motori Ferrari ma non mi risulta che ha le stesse prestazioni della Scuderia Ferrari o che abbia mai vinto qualche titolo in F1 .
                                          avanti con queste novità soima?con tutto questo casino bisogna aspettarsi di tutto
                                            Gru terri spa
                                            Buongiorno a tutti. Il sito ufficiale della Terri Spa è già online ed è www.terri.it. Nel sito ci sono le schede di 18 modelli di gru a torre top less da 30 a 85 mt di sbraccio. La Terri Spa è una società del gruppo Mevi e infatti ulteriori informazioni e immagini si possono trovare nel sito uffiale di Mevi www.mevi.eu.
